Message 1 of 9
I have a problem with a different sill height corner window. The second fixed panel does't cut the wall despite the fact I've modelled a void form.
I can not cut the host with the same void because the sill heights between panels are different.
Do you have any suggestion to fix this issue?
Thanks!
