Is it possible to set a section view where a category of Revit has a different visualization (like Trees in Realistic and Architecture in Hidden view? Just beacuse Revit Green objects are much better to see in this style,whether the architectural components seems better in the other.
Than you so much for your time.
Lorenzo
No, that is a global setting, not by category. To achieve that, you could overlay two views on a sheet, each using different settings.
I would use transparent PNG image and populate the plants.
But what happen when you use realisti view stile in plan, this wouldn't recognize same settings for rendering of the tree than of the elevation. Is it correct?
Yes, sure, it is the other way.It seems a light bit longer but, at the end...in plan the green category doesn't work to me as the same as in elevation, at the most
