Assembly with wall parts
yuvdal
yuvdal
I have created an assembly that include wall parts.
After creating the assembly I have duplicated it few times.
Later I wanted to make a change in the assembly but unfortunately I couldn't accommodate the change for all the other assemblies in one time (like group).
I made the change, the type name of the assembly was automatically changed but then I tried to match types but revit showed me an error that the assembly cannot be changed to selected type.
It seems that the problem is the parts.
I would be happy to hear if there is a solution for this issue.
Yuval
martijn_pater
"These tend to be parts...", so I think you might be right. But couldn't you just copy paste these?
yuvdal
Yes, I can copy paste this but this is not the solution that I am looking for because if for example I already have 20 assemblies in the same type and I have to change something, I don't want to delete all of them and copy and paste them again...
martijn_pater
...btw to copy it add the original to the assembly (show both ie.).
Also, I don't really know how to match it if matching doesn't work... I think it doesn't because it creates parts new when copied and then creating a new assembly always? Not sure. I get it's not ideal to copy them... Perhaps instead of using assembly you could group & link it, but also not ideal probably... You'd still have to copy&position them but you could edit the linked file sort of similar to an assembly maybe.
_Vijay
Try to disassemble one assemble then replace rest of them..
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
roman_panelo
In the view properties, look for "Part visibility" and set to "Show original". That will allow you to select the original wall assembly as a whole and make the changes desired.
azad.Nanva
use the group and make Assembly from the group.
