Using Families in Education Version
2 ANTWORTEN 2
Nachricht 1 von 3
269 Aufrufe, 2 Antworten
How do I use Australian Families in the Education Version. The construction items in my Revit are obviously American. I am trying to do a drawing with brick veneer external walls but this is not in the "Walls" library and I cannot see how to access the Australian Families that I have downloaded.
2 ANTWORTEN 2
Nachricht 2 von 3
_Vijay
als Antwort auf: Anonymous
you can download the library from below link. and use as usual in standard version. please choose corresponding version which you need.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/W...
Nachricht 3 von 3
ennujozlagam
check it HERE on how to install. thanks
