Array with two different element
niteshpanchal
niteshpanchal
Hello All,
I am facing a challenge with an array in the Revit family. As attached Revit project, I have an array of ceiling grids. I have a couple of ceiling tracks. One for the perimeter and one for the inner one. Now since the perimeter has a different profile, I can not start my array from the edge for inner tracks. But this needs to start at some distance from the edge track. This way I am unable to achieve equal distance for all the perimeter and inner tracks. Is there any formula or trick that can manage the above requirements?
Thank You!
Why don't you create a Profile Family using the extrusion profile in your CNT_Inner H_Frame Family and then use this Profile for Mullions in a Sloped Glazing Type. Sloped Glazing, like Curtain Walls, can have border Mullions that are different from interior Mullions.
niteshpanchal
Hi @barthbradley,
Thank you for your response, actually i would like to create this in family and not in project.
@niteshpanchal wrote:
Hi @barthbradley,
Why? It would be so much easier and way better BIM doing it in the Project via Sloped Glazing or Beam System.  But, if you have to create it in a Family, check out the one I've attached herein.  I think it'll be self-explanatory.
niteshpanchal
Hi @barthbradley ,
This looks close to my requirements, is there any way where we can set the offset value on each end same as the spacing value?
