How make sheet size parameter without moving texts
3 ANTWORTEN 3
Nachricht 1 von 4
ehsan_elahi
221 Aufrufe, 3 Antworten
Hi.
I want to make a sheet family for my project with different sizes (A1-A2-A3-A1+...) How make sheet size parameter without moving texts?
I make the sheet in title block and make dimension for sheet and give them a parameter, but when I change dimensions, the texts moving, or maybe the lines around texts moving. I want that the part of texts and project information lock and stay in their position and the size of sheet increase or decrees on the other side of sheet.
thanks
3 ANTWORTEN 3
Nachricht 2 von 4
vitorbortoncello
als Antwort auf: ehsan_elahi
Make another title block just for the project information
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 4
There are dozens of video and tutorials on-line of different approaches to building Titleblocks. Google and watch them all. But my very strong suggestion is to build separate and differently-sized Titleblock Families instead of fussing with building one Titleblock Family having many parametrically-sized Types.
Nachricht 4 von 4
SteveKStafford
I'll echo @barthbradley - the amount of available room for TB information varies quite a bit for each sheet size so making it adjust for different sizes is tedious. However, you can create groups of elements that need to move and use a dimension to move them via a parameter. It's possible, it just gets trickier the more you have to alter what the TB needs to look like for each size. So you have to decide if the ability to choose a different size in one family is "easier" for the end user than just choosing a different family for the other sizes.
Steve Stafford
