- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Can someone explain please WHY array in-place voids in an in-place component never work right?
it either gives an error regarding constraints to a member outside the group or it does array the voids, they go haywire all over the view when the in place component is stretched. I am not looking for the workaround of "use void family"... this is an exercise (weekend homework) for Revit lab at uni. And it is to either make a void array workable and controllable in an in place OR justify why it is not doable if we can't. The full grade goes to option 1 so it must be doable!
I googled a lot and checked several Revit forums with no luck. I find similar questions but none solves it or say why not doable using in place. So if there is anyone who is more of a Revit wizard who can explain it would be awesome and I would be in his or her debt for the rest of this semester
It's a rectangular extrusion with rectangular cut throughs which should
1. maintain distance of 400mm from all edges
2. Arrayed number adjust to length and width of host rectangle as it gets stretched
