Array annoyance
Array annoyance
thmbuildingdesigns
Observer Observer
Array annoyance
thmbuildingdesigns
Observer
Observer
WHY?
I have adjusted the projects levels height. Working on getting my sections completed, I array a detail item (roof joists), and the window where one enters tthe number of items you want the array to create is way off screen.
But, when the levels are left at 0'0" the array window is level with the items I am arraying...
Why can't the window adjust to be closer to the item that I am arraying?
Does it do that in the View?  You are showing it happening on a Sheet in a Activated View; right?
thmbuildingdesigns
Observer
Observer
The picture is showing it happening in the cross section view, but also happens when inside the view on a sheet.
Whatever. Are you unable to drag it back up? Is that it?
I mean, it does happen to me sometimes, but I can usually (not always) drag it closer though.  There's not really an indication that the element is selected, but going through the motions of dragging it (e.g. pressing the mouse button) usually drags it to the point where I let go of the mouse button.  This ain't working for you?  I don't know of any other method -- except saying "f*ck it!" and moving on to the next annoyance.
thmbuildingdesigns
Observer
Observer
Well I'll be! It never in all my 10 plus years of using Revit think for one second to drag the window up.
Thank you for the face palm I just did HAHAHA!
