3D Detail Workflow
2 ANTWORTEN 2
Nachricht 1 von 3
DrakeCanyonArchitecture
513 Aufrufe, 2 Antworten
3D Detail Workflow
I'm starting to lean towards doing more of my details in 3D. I have created a detail in it's own Revit file, locked the 3d view and annotated but am now perplexed at how to get that view imported into the drawing and placed on a sheet. I feel that I'm on the right track in creating a separate file for each detail and importing as needed as it isn't possible to do 3d drafting views (man I wish it was).
To be clear, I have been able to get it into the drawing in a few ways by saving as an image, pdf, etc, but they all seem to come in pixelated.
Kevin Mendenhall
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
2 ANTWORTEN 2
Nachricht 2 von 3
bdoig
als Antwort auf: DrakeCanyonArchitecture
It seems like the best way to accomplish this is to create the 3D details and have them available in a revit project template. Or you could insert your 3D details via Link Revit under the insert tab. Hmm
Nachricht 3 von 3
So far, the best results that I have been able to get is a simple screenshot of Revit and cropped in paint, then inserted into a drafting view as a JPEG in Revit so that I get the view title and ability to refer to it with markers. It's nowhere near the resolution that a native detail would be. In the attached screenshot, you can see a 3D detail that I did from the actual model in Revit on the upper right of the page, and my cropped JPEG in the lower right. As far as I can tell, the only way that I will be able to do this is by using a picture of the detail. I could import the model and go that route but I don't really want a bunch of stuff floating around in the drawing itself.
Kevin Mendenhall
