Hi there,
I have an area tag family i created and in that family i created a solid filled region.
The solid filled region i wanted to be controlled by a visibilty instance parameter.
So far so good I can do all this its fairly standard stuff.
However when i bring that tag to my project the Instance visibility parameter for the tag is not there.
Does anyone know how to fix this?
Solved by martijn_pater. Go to Solution.
Maybe i am doing something wrong. I created the instance parameter for the filled region in the family (called ''F & B'') but i can not see it in the project.
Attached is the family
haha! i know that but i need it to be an instance other wise i have to create loads different types.
I don't think that you can, but you would only need two different types - one for on and one for off.
The one i attached only has one color but i need many more.
Is there anyway to add instance parameter to an area tag family?
Not that I know of, nut you could create different types in the family and then choose from these - eg, colour 1, colour 2, no colour.
thanks for your help I appreciate it, I was hoping for no workaround, I will do a bit more research. This feels like somethign that should be possible.
It is not, it is a type based family. You could associate a global parameter though to the type if you need to 'instantly' change all of those in a different manner then to adjust the type properties in family/project browser. But otherwise you would need to create different types.
