Area Tag Calculation:
Is it possible to have an area tag that kicks out dimensions of the two legs of a right-sided triangle and the area of said triangle?  I currently have it set up to manually enter which is lame.  I struggle with these Revit formulas.
Any ideas?
Visit the thread below for a similar formula to show dimensions of a rectangular room in room tag.
https://forums.autodesk.com/t5/revit-architecture-forum/room-tag-width-x-depth-parameters-generating...
Thanks, @ToanDN .
I actually have previously used that thread you directed me to for getting the dimensions for my square areas!  Thanks!
However, how can I modify/control it to just pull dims from a and b?
@Anonymous wrote:
Thanks, @ToanDN .
Yes I realized the formula would be much more complicated than that.
A: Area
P: Perimeter
a: length 1
b: length 2 = A*2/a
I have arrived to:
P = a + (2*A/a) + sqrt ((a^2 + (2*A/a)^2)/2)
Now P and A are known, you have to find "a" from the above.  I am dizzy and giving up.
@ToanDN, thanks for your efforts!  Sorry to make you dizzy!
I will play around.  Thank you again!!
Cheers!
I mush prefer this kind of finding (attached).
