Hi, I've been tasked with creating area schedules to look similar to our excel schedules, having issues laying out the info as per the schedules created in excel. Does anyone know how I can create this type of schedule ? Or is there a better way to do it ?nAt the moment I have just made individual schedules per room (Mech. schedule, Gross Floor schedule etc..)as I am aware It wont look completely like the excel schedules. See attached image for more information on what I am trying to do.
Solved by RDAOU. Go to Solution.
Like this? see attached sample Version 2022 though... this is based on areas and area schedules. Simple:
If you are not using areas, you can create similar using Roombook/Areabook based on rooms
Thank you so much, this worked perfectly. My only issue is the FSR Area calculated parameter wont work, any reason why ?
Awesome, I'll give that a shot and see if it works. In another model which is linked I needed to add additional fields but its not appearing in the schedule now, did I do something wrong ?
