Area calculation of materials
mairh_tsek
mairh_tsek
Hello all,
I created a 'Material Takeoff' schedule for the Walls, as I want to calculate the total surface of each material.
I noticed that the surface depends each time from the way that the wall is joined.
1. Which is the proper way to join the walls in order to have accurate results?
2. Generally do you make another calculation of the material surfaces with another way or you 'trust' the results that Revit gives?
Thank you in advance!
Ilic.Andrej
Hello. Read this.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
