Architecture Family Display in Plan
9 REPLIES 9
Message 1 of 10
Jake_PCH
470 Views, 9 Replies
Jake_PCH
The attached toilet family shows in 3D & Elevation but not in plan. Can anyone propose a resolution to this issue?
Kind regards,
Jake
Kind regards,
Jake
9 REPLIES 9
Message 2 of 10
Simon_Weel
in reply to: Jake_PCH
Simon_Weel
There's an override - it's set to NOT show in plan:
Message 3 of 10
Jake_PCH
in reply to: Simon_Weel
Jake_PCH
Thanks for your response Simon.
However, I believe you are referring to the lid. The bowl is shown to be visible in plan, yet it is not.
Message 4 of 10
Mark_Engwirda
Mark_Engwirda
@Jake_PCH  Appreciate you are trying to show the 3D model in your plan view but the best practice for families with complex shapes is to use a 2d mask to represent the view in the plan and elevations etc and leave the 3D models for 3D views.
Message 5 of 10
SteveKStafford
SteveKStafford
Hmm, when I opened the family I only saw the lid... downloaded again and the whole fixture is there. The nested family for the bowl is also not set to be visible in plan (select the element > visibility settings).
Steve Stafford
Steve Stafford
Message 6 of 10
Jake_PCH
Jake_PCH
@Mark_Engwirda, while I appreciate the advice and will investigate this method at a later date, for now I would like to understand why this family is not showing in plan.
Below is a screenshot of the plan view of the family in the family editor;
I have ensured plan view is ticked in both the host and nested family, yet still not showing in model space.
Has anybody been able to get this plan view to show in model space?
*Update: I have since discovered that when I select 'Reveal hidden elements', the plan view appears. However, they do not appear highlighted to indicate they are being hidden individually, by a filter or template - see screenshot below.
Does anyone have any suggestions?
Message 7 of 10
Simon_Weel
Message 8 of 10
Jake_PCH
Jake_PCH
RESOLVED: Visibility/graphic Overrides - Imported Categories - Imports in Families.
If someone could explain why this family is classified within imported categories, that would be appreciated.
Message 9 of 10
Mark_Engwirda
Mark_Engwirda
@Jake_PCH its not uncommon for complex shapes to be modelled in other software and then imported into a Revit family as a time saver.
Message 10 of 10
Jake_PCH
in reply to: Mark_Engwirda
Jake_PCH
That would explain it - thanks for your input, Mark! 😊
