Clt wall materials not visible
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
katsanosengineer
414 Aufrufe, 7 Antworten
I made a CLT wall out of basic wall, adding 5 layers with different material and the preview is fine.
But it doesn't look like this out of the edit assembly preview, regardless the visual style.
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: katsanosengineer
If you want the edge of the wall to show different layers then create parts from the wall and set the 3d view to show parts.
Nachricht 3 von 8
katsanosengineer
als Antwort auf: ToanDN
Thank you for your response, but how can I create parts from the wall?
Nachricht 4 von 8
handjonathan
Hi @katsanosengineer
Thanks a lot for posting your question to the forums!   Please see more details here on how to create parts for your project.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 5 von 8
katsanosengineer
als Antwort auf: handjonathan
Thank you this really helped
Nachricht 6 von 8
katsanosengineer
Thank you, but when I create parts out of it I can't modify the wall like before. There is no option that I can see the layers and modifying the wall as one piece?
Nachricht 7 von 8
handjonathan
You can still modify the original wall, Parts are automatically updated and regenerated when the original element from which they are derived is modified. Such edits might include adding/removing layers, or changing wall type, layer thickness, wall orientation, geometry, materials, or openings.
On the Properties palette, under Graphics, select the Show Original option from the Parts Visibility drop-down list and then modify to update.
Jonathan Hand
Nachricht 8 von 8
katsanosengineer
Thank you!
