'Architectural Template' or Construction Template'
2 REPLIES 2
1645 Views, 2 Replies
I am new to Revit Architecture, I am coming from AutoCAD Architecture background, I work as an Architectural Technician. I am currently attending a night course in Revit Architecture.
I purchased a new PC comply with the requirements to run Revit, I have downloaded the Revit Architecture from the student section on the Autodesk site.
My problem is I don't have the option of an 'Architectural Template' or Construction Template' in the opening section of the Revit programme.
Can somebody advise.
2 REPLIES 2
David_W_Koch
David_W_Koch
You may find some useful information in this thread.  In particular, look for posts by tony.michniewicz.  If I recall correctly, there was an issue with the content on the student site (may have been fixed?), and he offered some things to do to overcome the issue.  You do need to have an active internet connection while installing, as the content is downloaded during the installation.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
David Koch
Blog | LinkedIn
in reply to: David_W_Koch
David,
Thanks for your reply - I will check it out
David,
