Arched fill pattern on floor
adkaJK5HX
adkaJK5HX
Hello!
Is there a way to align the fill pattern of the floor so it follows the angle? I have been thinking about dividing the floor into smaller pieces and then adjusting the pattern for each.
jay_colcombe
The only option you have within Revit are as shown below in the Edit Pattern Properties.
In this instance you will need either the Pattern to be similar to the Arc or a Third Party Addin which will allow a Tapered/Scaled Pattern Placement
Jay Colcombe
Autodesk Certified Instructor
hmunsell
Short answer is No. You can control it thru the hatch properties as @jay_colcombe shows, you should also be able to tab select one of the lines in the pattern and use the Rotate command to change the angle of the pattern. But either way, it will not conform to the curve of the shape.
Howard Munsell
