Arch Top Pocket Door
3 REPLIES 3
leahmbell
123 Views, 3 Replies
Does anyone have a work around to create a pocket door with an arched top?
If you use a void you can't get the wall to cut an arch at the top.
If you use an opening you can't get the pocket for the door.
You can't have a void and an opening in the same family.
To clarify it is a rectangular pocket door with an arch top opening.
3 REPLIES 3
in reply to: leahmbell
Huh? Sounds like this is about an Opening and a Void both not being able to cut the Host Wall in the Family.   Am I right?
Don't cut the Host Wall in the Family with both an Opening and a Void. Leave Void unattached and check cut's with Void when Loaded and cut it manually in Project using Cut Geometry  -- or delete the Opening and cut the Host Wall with 2 Voids.
Mike.FORM
You can definitely accomplish this with 2 voids as @barthbradley said.
See attached family template you can use as a starting point.
Sure you can use a void or multiple voids to cut the wall with an arch at the top AND the slot in the wall cavity for the door to pocket in.
Forma Design Contest
Technology Administrators
