Arc shape Floor edge are not clear shape
6 REPLIES 6
Prakash.C
383 Views, 6 Replies
In the above image 01 Floor is nor clear in ARC shape its look like pixel less image, i am placing sweep work in edge of the floor i cant to select the correct edge , kindly give me solution for the floor edge .
6 REPLIES 6
in reply to: Prakash.C
Create an edge beam with that profile and apply.  It may work better.
Prakash.C
This a road model we creating the road in floor so we cant add additional beam because floor fully we add modified points, and i attach the section of the model the side kerb we done in sweep its also not look same shape in sections .
Are you using a profile for this, or drawing the profile in the sweep command?  It normally works better if a preset profile is created and then use that in the sweep.
Prakash.C
04.PNG05.PNGthank you for your response, already we inserting the profile type in sweep command, but that also we dine get clear floor edge and clear section. its look like pixel issue or graphical issue
- Is your model far from the Origin?
- A railing may work better
in reply to: ToanDN
Ditto. That's exactly what it looks like.
@Prakash.C :
 https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/...
