Halo,
I have the following problem: i have over 100 models of one project. We lately found out that our origin point is wrong. I did some research and found out that it is not possible to move the project internal point (PI). I tried to relocate project, move the project base point (PBP) or the survey point (SP), but still then PI stayes the same. This is no go as the clients wants the models for the caleboration with other parties and wants origin to origin (for unknown reason). The only possible way is to move al the elements in 3D and 2D, this can be sensible to errors.
Question: i was wondering if its possible to move the IP through python in Dinamo? if so can anyone help me with this please? Any other suggestions are welcome.
regards,
Sahar
Do the individual model for each discipline line up with each other? For example, Building X architecture and Building X structure align?
If yes to above...then Shared Coordinates can be used to reconcile building locations consistently so they can be exported to Navisworks, for example, for coordination.
If no to above then you may be able to use positioning: Auto - Project Base Point to Project Base Point. Move the PBP unclipped to a specific grid intersection. Have all models (specific building) do this the same way. Then they can be linked into each other so they align.
Steve Stafford
