Apps that you can delete
emmamoreno1515
emmamoreno1515
Community Visitor
Community Visitor
My computer at work has gotten super slow due to lack of storage. Upon further investigation, I realized that this computer has been around for quite a few years and I had multiple versions of Revit & AutoCad going back to 2020. I've deleted a considerable amount of applications but there's a few I'm not sure if I can delete. I use the 2024 version of Revit currently, but I have apps named "Autodesk Advanced Material Library Medium Resolution Image Library 2021" (and the 2023 one)  and "Auto desk Revit US English Base Families 2021."
I did some research and one Autodesk Help Guide said that everything is installed within Revit 2024 but I just want confirmation before I go and delete things (especially off the work computers) Thanks in advance!
Simon_Weel
You can uninstall all Autodesk stuff for versions you don't have installed. So for example, if you have AutoCAD 2022 and Revit 2024, then you can uninstall anything except 2022 and 2024.
Lachlan-JWP
Delete this folder.
It's just a bunch of junk installation files from Autodesk.
In addition, clean up your local files and their backups (located in "My Documents"), as well as the journal files (located here: C:\Users\"User"\AppData\Local\Autodesk\Revit\Autodesk Revit 2024\Journals)
There can be a lot of space taken up by backup files that may no longer be relevant to your current work.
