Applying hatches to bathroom floor finish
jinergoh721
Message 1 of 9
jinergoh721
I am trying to figure out how to do floor finishes hatch for wet areas aka bathroom,
I tried to use split face and Paint under modify tab but it don't quite works.
Is there any solution to do this?
Replies (8)
Message 2 of 9
You need to paint the area with a material with a surface pattern.
Message 3 of 9
se.ha
Hi @jinergoh721,
we create different floor types for different floor finishes. For example Hardwood floor in the living- and bedrooms, tiles in the bathrooms. That makes it easier to apply materials (and therefor hatches), you can use it in schedules or create filters and graphic overrides.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Message 4 of 9
jinergoh721
Hi @se.ha ,
i know we can modify material properties and visibility graphics for floors,
but I want to apply only at certain portion of floor, so is there any way where  I could  slice them up and apply floor hatches to bathroom only?
Message 5 of 9
se.ha
I just tried the way you mentioned in your Original Post:
Split Faces and apply Material to this face - works like a charm.
Split Faces | Revit 2022 | Autodesk Knowledge Network
Apply a Material to the Face of an Element | Revit 2022 | Autodesk Knowledge Network
se.ha
Message 6 of 9
jinergoh721
Thanks dude!
Message 7 of 9
jinergoh721
@se.ha
You're a genius! to find the split face video ..
It makes everything simpler a lot, I previously failed to use cuz of some minor clicks.
Message 8 of 9
jmhanbyV4TDM
We do this as well.
Message 9 of 9
jinergoh721
Apart from paint,
can go to <Remove paint>.
Then <EDITTYPE>, <FINISH MATERIAL>, <MATERIAL PATTERN> ,<SUFACE PATTERN>, for floor plan, <SELECT HATCHES>
So instead of applying paint just like change material browser, kinda..
Workshop C2 , wk8 2/05/2022
For personal reference, vague.
