Applying cladding material on truss system
Non applicable
666 Visites
1 Réponse
Message 1 sur 2
Non applicable
I have made this truss system & want to apply fibre board cladding on it. Currently, the method that I am following :
1. Creating an extrusion family of the respective face of arch profile with a lesser depth (depth equivalent to cladding material depth).
2. Placing that profile on face of arch in project file.
3. Applying the desired material on the surface & rendering.
Same procedure I was thinking to follow for all the faces. Wanted to know of other methods for doing the same.
0 J'aime
Solutions acceptées (1)
667 Visites
1 Réponse
Message 2 sur 2
RDAOU
Solution acceptée
@Anonymous
Apart from adaptive components; here is one way to do it using the same In Place mass wireframe which you created in the model you uploaded. This allows you to create a parametric mass that follows the Truss's wireframe.
There are other methods but that is what came first to my mind. Maybe others have better and more simple ideas
