Applying Alpha Channel as a material?
ro
ro
Is there a way to apply the Alpha Channel as a material?
You can apply it as a Cutout.
ro
Thanks ToanDN,
I'm searching for an application, for example, you create the neighbors as an alpha channel and then you don;t need to ask it into an image.  That's just one example.
RO
JM_Koester
At least all the new PBR materials ignore alpha channels, you need to extract the channel and save it as a separate mask grayscale image.
I guess it will be the same for legacy materials.
