Appereance parameter for glass
Message 1 of 26
Hello, I do render but glass parameter it's not good.
Seems plaster.
Someone can help me?
Can't charge model. Connection bad.
Can download project here:
https://forums.autodesk.com/t5/revit-architecture-forum/problem-with-elevation-sheet/m-p/9329682#M27...
Thank's
Replies (25)
Message 2 of 26
MostafaElashmawy
Couldn't find the revit file in the mentioned post.
Mostafa Elashmawy
Message 3 of 26
Looks fine in your screenshot, but you can play with the Material Appearance settings, such as Transparency. Also, you can experiment with different Assets like this:
Message 4 of 26
Message 5 of 26
@barthbradley  @MostafaElashmawy  now is more important this, sorry.
Glass railing without handrail?!?!
I can't put "none" for hanedrail.
This is the post:
https://forums.autodesk.com/t5/revit-architecture-forum/create-a-railing/td-p/9331394
Thank's
Message 6 of 26
edit: I don't understand
Do you want to remove the Top Rail and Bottom Rail???
Message 7 of 26
@barthbradley
They ask me something all glass for railing but without handrail as in pic.
The easer command is "curtain wall" but don't know how can do with inclination stairs.
Answer in other post, please.
Thank's
Message 8 of 26
Message 9 of 26
MostafaElashmawy
try changing the color to white, or better to light blue.
Mostafa Elashmawy
Message 10 of 26
That's a little more involved. You need to do a custom railing for glass panels. Procedure is talked about here:
https://www.autodesk.com/autodesk-university/class/Designing-Custom-Railing-Panels-Revit-2017#handou...
Message 11 of 26
@barthbradley  I can't do an curtain wall inclined?
Message 12 of 26
I'd do it as Railing myself.  It isn't that difficult.  Just requires a little math and prep work.  You ought to learn how.  Read the information I posted and watch the Video too.
Message 13 of 26
@MostafaElashmawy
where i can go to change parameter of panel..?
Sorry
Message 14 of 26
open the TYPE Properties for the Panel Family itself and change there.
Message 15 of 26
@barthbradley  seems better but don't view the mullion grid.
Message 16 of 26
Yes, the grid is invisible. If you want to see the edges of the glass panels that are align to the grids, maybe you need a different angle or more render time.
Message 17 of 26
@barthbradley  @MostafaElashmawy  have to give less untrasparency of mullion?
Message 18 of 26
What are you talking about, @Anonymous ? You have no mullions to render or make less transparent.
Message 19 of 26
@barthbradley  sorry. i'm talking about the grid.
There are no mullion, sorry.
I wait.
Message 20 of 26
@barthbradley  don't seem as well very much.
Change angle of 3D view you speak about?
Thank's
