Appereance parameter for glass
Message 1 of 26
Hello, I do render but glass parameter it's not good.
Seems plaster.
Someone can help me?
Can't charge model. Connection bad.
Can download project here:
https://forums.autodesk.com/t5/revit-architecture-forum/problem-with-elevation-sheet/m-p/9329682#M27...
Thank's
Replies (25)
Message 21 of 26
@barthbradley  maybe if I do little less transparent i view them more?
Thank's
Message 22 of 26
Thank's
Are you still referring to Grids?  Grids DO NOT Render. Did you read Message #17?
Message 23 of 26
@barthbradley  to view curtain walls.
Put less trasparence  in panels so.
Message 24 of 26
MostafaElashmawy
You can hover over the panel then press tab till it's highlighted yhen select it.
Mostafa Elashmawy
Message 25 of 26
@MostafaElashmawy  to view the curtain wall and not a trasparent wall as in my pic post before?
Message 26 of 26
MostafaElashmawy
You need to reduce the transparency
Mostafa Elashmawy
