Hello, I do render but glass parameter it's not good.
Seems plaster.
Someone can help me?
Can't charge model. Connection bad.
Can download project here:
Thank's
Gelöst! Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Couldn't find the revit file in the mentioned post.
Mostafa Elashmawy
Looks fine in your screenshot, but you can play with the Material Appearance settings, such as Transparency. Also, you can experiment with different Assets like this:
@barthbradley @MostafaElashmawy now is more important this, sorry.
Glass railing without handrail?!?!
I can't put "none" for hanedrail.
This is the post:
https://forums.autodesk.com/t5/revit-architecture-forum/create-a-railing/td-p/9331394
Thank's
edit: I don't understand
Do you want to remove the Top Rail and Bottom Rail???
They ask me something all glass for railing but without handrail as in pic.
The easer command is "curtain wall" but don't know how can do with inclination stairs.
Answer in other post, please.
Thank's
try changing the color to white, or better to light blue.
Mostafa Elashmawy
That's a little more involved. You need to do a custom railing for glass panels. Procedure is talked about here:
I'd do it as Railing myself. It isn't that difficult. Just requires a little math and prep work. You ought to learn how. Read the information I posted and watch the Video too.
Yes, the grid is invisible. If you want to see the edges of the glass panels that are align to the grids, maybe you need a different angle or more render time.
What are you talking about, @Anonymous ? You have no mullions to render or make less transparent.
