Appearance of a Multi-Categry Schedule in Layout vs. in Working (?) view
1 REPLY 1
561 Views, 1 Reply
I would like to dedact some parts of the Multi-Category Schedule (to only show the measurements of units of quantities valid for the given materials)
This seems achievable in the working view mode, but when I place the schedule in a layout, the dedaction is no longer visible.
If this setting cannot be transfered to the Layout view, is there a similar method that can be used to dedact some parts of the schedule?
1 REPLY 1
fernanda.firman
I am not sure how you are setting up your schedule but you can use the "filter" to filter only the information you want to show.
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
Forma Design Contest
Technology Administrators
