Any way to turn off the "line too short" message? I need to create 0.7mm plating and i simply can't
S1139363
Observer Observer
Message 1 of 9
S1139363
Observer
Observer
Hi everyone!
I need to create a custom profile plating with a width of 0.7mm, and simply can't because of the lines being too short (under 0.8 mm). Is there any way around this? What steps would you take to create a custom sheet metal profile?
Replies (8)
Message 2 of 9
RSomppi
This is a documented Revit limitation. There is no way around it.
Use a different program designed for fabrication to get your desired results.
Message 3 of 9
syman2000
Only way to achieve this is to create thicker solid and use void to cut off the access.
Message 4 of 9
RSomppi
That's not achieving it, it's not even a work around. That's just plain faking it for a drawing and doesn't accomplish anything close to creating a profile.
Message 5 of 9
Lachlan-JWP
Do you need to be exact? When I work in Revit my tolerance is 5mm, to create a profile that is 0.7mm when built, I would just make it 1mm thick to make it work in Revit. The difference would not matter to the rest of my model.
Message 6 of 9
Simon_Weel
Vote the idea...
Message 7 of 9
FPutnamLPUQW
This is one thing that has always irked me about revit.  I get not allowing model objects to go too precise as that would just bog down the processing of 3d objects but WHY cant I make detail lines in drafting views as small as I want?!  Like we're never going to have to draw a metal stud in a detail or something.
Sorry I'll get off my soap box... To answer your question I think everyone else has said it already... can't do that here.  create a profile that represents .7mm as thin as you can (1mm?)  I know in imperial its 1/32" which for a building component is pretty tiny.  If you are making fabrication drawings... I'd use Inventor or Fusion 360
Message 8 of 9
NZhouSNYLF
i believe RVT limit is 0.8mm (1/32") but RFA is 0.2mm (1/128") so you can do it in family, any workaround for below 0.2mm (1/128")?
Message 9 of 9
RSomppi
It's a limitation by design. Any attempt that works will likely break eventually. I would advise avoiding trying to get around this.
