Is there a way to edit the Path of travel directional arrow and starting point circle symbols so they are bigger than the default sizes?
2 ANTWORTEN 2
Nachricht 1 von 3
emmanuel_boakyePJCYR
808 Aufrufe, 2 Antworten
The default size of the path of travel directional arrow and starting point circle are quite small and I'm wondering if there is a way to edit the sizes so that they are a bit bigger
2 ANTWORTEN 2
Nachricht 2 von 3
This is not possible at present and only by placing another scalable or larger annotation at the start/end can this be achieved.
Ability to adjust start and end symbols for Path of Travel tool in Revit (autodesk.com)
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 3
Unfortunately as above you can either added another symbol over the top or increase the line weight in object styles (it does increase the size of the symbols just probably not enough)
