Any way to change the "Read Convention" of some dimensions, but, not all?
Message 1 of 22
We have our Dimension Style's Read Convention" set at "Left, then Up", which works fine for most dimensions.
But, if we're dimensioning an object that runs from the Upper-Left of the display to the Lower-Right, the text reads upside-down.
Is there a way to correct this?
Read Ya Later -KLYPH
Replies (21)
Message 21 of 22
bicax22034
if you want to change the "Read Convention" of specific dimensions but not all, you can typically do so by modifying the properties or settings of individual dimension elements. Most design software or why does it matters CAD programs allow you to customize dimension styles or properties, which include options like "Read Convention" or "Text Placement."
Message 22 of 22
bicax22034
Yes, it is possible to change the "Read Convention" of individual dimensions in certain CAD software. The specific steps may vary depending on the software you are using, but generally real time , you can follow these general steps:
