Any way to change the "Read Convention" of some dimensions, but, not all?
Message 1 of 22
We have our Dimension Style's Read Convention" set at "Left, then Up", which works fine for most dimensions.
But, if we're dimensioning an object that runs from the Upper-Left of the display to the Lower-Right, the text reads upside-down.
Is there a way to correct this?
Read Ya Later -KLYPH
Replies (21)
Message 2 of 22
Upsidedown? Say what?
Like this?
Message 3 of 22
Message 4 of 22
My dimensions are never upsidedown. I'm not even sure I would know how to do an upsidedown dimension.  Never really tried until now. I just rotated a view on a sheet in my previous post.
Message 5 of 22
I have never had any upside-down dimensions either.
But, today, there they are.
They are not acceptable.
That dimension in the photo is a quite normal dimension, just upside down text.
Anyone out there have a solution.
Read Y'all Later -KLYPH
Message 6 of 22
Are you saying you can't correct it???  I'd be hopping mad.  I'd be on the phone to Autodesk.
Message 7 of 22
georgehobel
I think I have seen that happen when I rotated a view.  If you rotate a view on a sheet, the words and dimensiones rotate with the view...
dont get me started...i dont need no hopping around...
George Hobel
Reflections of Charlotte
Residential Building and Design
Message 8 of 22
Well, that's embarrassing for REVIT
I've been with this firm for so long I can't remember. At least 15 years.
All that time on AutoCAD. Now REVIT.
All the boss cares about is how the finished sheet looks.
It's hard to explain why some we've been doing for decades is no longer possible.
Surely there is a solution.
Anyone out there with an answer?
Message 9 of 22
Are you saying the upsidedown text is because of the view is rotated on the Sheet? If so, rotate the View Crop Boundary.
Message 10 of 22
If I rotate the view to make that one dimension correct, then many of the dimensions that are currently correct will become incorrect.
I tried it.
See the sketch above. All except the one upside dimension are correct.
If I add another dimension running from upper-left to lower-right, that dimension will be upside-down.
Again, anyone out there with a solution ?
Message 11 of 22
I'm not fully understanding. Are you saying that you cannot get it upright in the VIEW itself?  That this is only happening upon placing the View on the Sheet?
Message 12 of 22
On the Sheet A2.2, there is a View 8/A2.2 of the Cross Walk on the Site drawing.
We activate the View and place the dimensions.
Again, all of the dimensions are correctly oriented, except those running from Upper-Left to Lower Right.
Any help out there ?
Message 13 of 22
georgehobel
"any help out there?"...
uhhh..this is what help looks like.
Maybe its time to post the file itself,
George Hobel
Message 14 of 22
Okay, I get it.  What I was suggesting was to NOT rotate the View on the Sheet, but rather rotate the View's Crop Boundary instead. Does that workflow correct the upside-down text issue?
Message 15 of 22
georgehobel
I can take one of my drawings, place it on a sheet, activate it, add dimensions, and everything works the way its supposed to..
I can take that same drawing, place it on a sheet and add a rotation to the view.  then go activate it, and add a dimension... some of those dimensions are upside down...
That's your issue, there is a rotation that has been applied to that view on the sheet...
George Hobel
Message 16 of 22
georgehobel
again...
i can take my same drawing, and rotate the crop view as Bradley suggested, prior to placing on the sheet, and the dimensions all show correctly..
George Hobel
Message 17 of 22
I want to thank both George & Bradley for their explanation.
I just recently started work on this drawing and hadn't noticed that the original drafter had rotated the view.
This is another example of how truly useful these discussion groups are.
Again, THANKS -Klyphy
Message 18 of 22
georgehobel
Ive noticed that using Revit is a lot like playing Super Mario... you can go for weeks or months without finding the secret passage ways.. then occasionally you bump your head on a coin that you didnt know was there, or smash your face through a brick wall to find a hidden treasure...
Then you get hit replay and do it again....for hours....
George Hobel
Message 19 of 22
You're welcome.
You can give  more than one Solution Credit. Solution Credits are always appreciated. One more today and I get a free toaster.  😉
Message 20 of 22
georgehobel
so......  how do you like your toast?
George Hobel
