Any alternative to Parametric Arrays?
8 REPLIES 8
Message 1 of 9
Sahay_R
490 Views, 8 Replies
Parametric arrays in families have one glaring flaw - that they have a minimum count of two. What I only want one instance of the nested family in one case and 15 instances in the next?
Is there any other way to accomplish this?
Any thoughts?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
8 REPLIES 8
Message 2 of 9
in reply to: Sahay_R
Use a formula to turn off the array members when only one member is required. Place that single member separately as a non arrayed element.
Message 3 of 9
Sahay_R
in reply to: ToanDN
Thank you, @ToanDN. Just as I had thought. What makes things a little stickier is that there already is a different piece at the end of the array, which give a minimum of three.
Rina Sahay
Message 4 of 9
in reply to: ToanDN
Yes, and that visibility formula would interact with the array count (e.g. visibility parameter formula = array count<2)
Message 5 of 9
Or use an adaptive family with a divided path. It can have a minimum of 2 adaptive points, start and end.
Message 6 of 9
in reply to: ToanDN
A repeater? That one's harder to visualize
...BUT THANK YOU ANYWAYS MY FRIEND!
(yelling? no. Just inside joking with you. Smiley Wink
Message 7 of 9
Sahay_R
in reply to: ToanDN
And place the nested families on the points on the adaptive path?
Rina Sahay
Message 8 of 9
The nested family is also an adaptive family with one adaptive point. Place it on one point of the divided path and use Repeat tool to populate it.
Message 9 of 9
Sahay_R
in reply to: ToanDN
Aaahhh!! NOW I know what @barthbradley meant when he talked about Repeaters!
Rina Sahay
