Annotation Problem!!
Ahmad-Ramadan
Ahmad-Ramadan
I only have an access to a few orders in annotation tab in my current project
I don't know what's different between this project and the others !!!
I hope i get the answer
The view is controlled by a view template, this can limit functionality.
Hope this helps.
Ahmad-Ramadan
Thanks for your reply
but, it happened also in this project when i create the view without Applying a view template!
Alfredo_Medina
What version of Revit is this? Looks like a problem that affects the ribbon when a newer version is installed but you use the previous one. This can be corrected by installing the update packages.
Ahmad-Ramadan
Thanks for your Reply
You are right i am using Revit 2015 in this Project and Revit 2017 is already installed in my PC .
but, how can i install update package ?!
If you have Autodesk Application Manager installed just open the app to check any available update for all Autodesk programs you have.
Alfredo_Medina
Or, you can search in the Autodesk website. I found this link, which says that it includes the previous packages:
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
