I'm working in the student version of Revit 2017 using an ASCENT manual:
Autodesk Revit 2016 Architecture Fundamentals -- Imperial
In trying to set up a Structural template to use, the instruction is to:
Match the Autodesk Revit Structure interface, select Structural Template in Template File Locations, move it to the top of the list remove the
Architectural Template, Construction Template and Mechanical Template.
After doing this and exploring the Structural Template for a bit, I find that the Arch, Const & Mechanical Templates are no longer on the REVIT menu upon opening but the templates are no longer on other architectural project files either.
All files show only Structural Template in File Locations.
Can anyone tell me how to restore the Architectural Template, Construction Template and Mechanical Template files to default settings while keeping the Structural Template too.
Best,
Tommy M.
