Annotation Families
Annotation Families
Message 1 of 11
Annotation Families
 I Made annotation material tag, it easily read the description and type mark of the material and line of the arrow snaps 90 Degrees correctly.but as the description become in two lines,the arrow line doesn't work correctly as it doesn't snap the 90 Degree itself and should be done manually.
My Question is,
Is there any Way to Resolve this problem in Revit?I want the Material description to be in two lines and the arrow snaps straight correctly.
Replies (10)
Message 2 of 11
A leader to an annotation is always to the midpoint of an edge of a imaginary bounding box of the family.  See the attached family for a workaround.  With that said, it's best to avoid putting you text out side of the symbol for the family.
Message 3 of 11
Thanks for your information, Would you please make imaginary boxing more clear?
The symbol and the text under it are actually in an imaginary box.but the arrow still doesn't work.
Message 4 of 11
Imaginary box???  Google translate must be broken today.
The leader line originates from the mid point of the tag. Are you saying it is not?  Can you post the tag?
Message 5 of 11
I mean Bounding ,lol
Message 6 of 11
Please have a look on attached family
Message 7 of 11
Message 8 of 11
Message 9 of 11
See the revit file i ve attached in post 2.
Message 10 of 11
Tricky, @ToanDNSmiley Wink
Message 11 of 11
1.PNG2.PNG3.PNG4.PNG5.PNGat least you have to make invisible line in family and load it to project.at least you have to make invisible line in family and load it to project.at least you have to make invisible line in family and then load it to project.
