- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I have read all the forums that I could possibly find but I still haven't managed to make my Adaptive family work as I want.
What I did was I created a 2 point adaptive family as my "profile" so that I could schedule its length and cut its ends with certain angles.
Then I loaded this "profile" to my 4 point adaptive family and attached its ends to the adaptive points so that my "profile" would stretch together with the corners.
I want my profile ends to be cut according to the angles of my corners. So I made formulas with angle instance parameters (not reporting) that would cut my "profile" ends. It works fine in the family when I stretch the corner points, but when I load the family to a project the actual corner angle is not the same as my instance parameters. I tried making reporting angled parameters to be used in my formulas but I get an error message saying "A reporting parameter can be used in a formula only if its dimension references are all to host elements in the family."
Could someone tell me what am I doing wrong?
I have attached my 4 point adaptive family ("Corner test.rfa").
