Angled wall & windows
10 REPLIES 10
Message 1 of 11
info
1437 Views, 10 Replies
I have an existing structure which has an angle wall and a window frame that matched the slope of wall.
Please find attached.
How do I go about constructing that in the model?
10 REPLIES 10
Message 2 of 11
in reply to: info
There are many ways to model those but the below should be the easiest.
Angled wall:
Window:
 A curtain wall with edited profile to match the angled wall.
Message 3 of 11
info
in reply to: info
Thanks for that.
Message 4 of 11
in reply to: info
I think to get here:
you're going to need to go here:
Tapered w/ Angle Overrides
Message 5 of 11
in reply to: info
I should clarify something. The wall in the above screenshot is NOT 8" as the Type Name suggests.  It's 1'-4". In order to get something closer to the Tapered Angles you show in your screenshot, the width of the Wall will need to be even greater.
Message 6 of 11
info
in reply to: barthbradley
Thanks barthbradley,
I'm only worried about how to create a sloping wall (perpendicular to the view)  & window to match.
I'm not sure what the slightly taped line next to sloping wall is. But thanks for your post.
Message 7 of 11
info
in reply to: ToanDN
I can't find the setting for slanted wall. please see attached.
Message 8 of 11
in reply to: info
Which version are you using?
Message 9 of 11
info
in reply to: ToanDN
2020
Message 10 of 11
in reply to: info
@info wrote:
2020
Slanted an tapered walls are not available in 2020.  You will need to create the wall using one of the following:
  • Create a sloped mass and create a wall by face
  • Create an in place wall
  • Create a roof instead of a wall
Message 11 of 11
info
in reply to: info
Thanks.
