Analytical properties greyed out
Marcus.Isacsson
Marcus.Isacsson
Hi!
Does someone know why the analytical properties gets greyed out?
How can I unlock them?
(want to enter the U-value)
The properties are calculated based on the roof compound layers.
edit the material
chrisplyler
Because they are values that are DRIVEN by the layers defined for the roof and the properties of the specific materials used therein.
oh...so the solution is to "edit the material".  I was close.
...actually, no. I was spot on.
You should never posted an answer late Friday afternoon.  It will get ignored.
chrisplyler
I liked your answer better than mine anyway. Simpler is better. I just wanted my name in the hat, you know? I got lucky on the draw this time.
