AMD Radeon Vega 7 for Revit
3 REPLIES 3
Serhii_Leshchenko
4824 Views, 3 Replies
do somebody knows if it will be possible to work in Revit/AutoCAD (simple models) on a laptop with integrated graphics card AMD Radeon™ Vega 7?
Labels (5)
3 REPLIES 3
Hi @Serhii_Leshchenko
Yes you can work but with certain limitations (initially it will not be noticed), can work with a minimum 2GB card.
But if you want to work with renders it will not reach you.
Jamhmer Oc
if you can practice well in 2D plan there will no any problem but if you working a lot with 3D view you will face some problems because 3D navigation also consume GPU
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
You will experience some lag in your program if you don't meet the requirements to run the product. there are certain requirements to run latest version of REVIT you can refer to this LINK. thanks
Forma Design Contest
