Ambient Shadows on Sheets
Message 1 of 9
Hello.
Maybe some of you guys had the same issue and found the solution.
Something "snapped"  and in all files on all pc's in revit 2018 we have the same issue.
When ambient shadows turned on, revit will not crop them to view crop. They shows on sheet.
I attached 2 examples.
Regards
Replies (8)
Message 2 of 9
Any chance setting up a view template first with the right graphic settings?
and perhaps try using scope box for view crops
Message 3 of 9
Message 4 of 9
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community! Smiley Happy
Yes, a similar issue is under investigation for a resolution.
Did you try the workaround of Printing to PDF to generate a raster image of the view?
Regarding your issue, I would like to add your files to the existing case for further feedback.
Also, can you share a file and your export settings? I can send you a private folder if you'd like.
Meanwhile, can you confirm if you have the latest updates for your Revit version?
Looking forward to your reply update.
Message 5 of 9
i started this case with Autodesk support.
I work on revit 2018.2
Best regards
Message 6 of 9
Viveka_CD
Hi @Anonymous
Can you share the case number?
Message 7 of 9
Message 8 of 9
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thanks for posting about this programm behavior.
In order to help other customers running into the same issue, finding the investigation quickly and following up on its status easily I will  mark your post with the link to the related knowledge article as an "Accepted Solution".
We will keep this article updated with news as soon as those are available.
Best regards,
Zsolt Varga
Technical Support Specialist
Revit Ideas | Screencast | Revit Help | AKN
