schedule show items on different height
3 ANTWORTEN 3
Nachricht 1 von 4
291 Aufrufe, 3 Antworten
I have a wall schedule which shows the properties of the wall. They didn't shown on the same height. Anybody knows how to fix that. look plz on the photo.
thanks
Tags (2)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
If I understand your question correctly, you are talking about the height of the cells in your schedule? or the height of the walls you mentioned?
If I assume you are talking about the schedule, then you simply need to adjust the width of your other columns, it looks like you have a column next to the height which is being text wrapped, forcing the entire row height to increase.
Nachricht 3 von 4
kadmonkee
adjust the columns 70-450 and 4400 justification to be middle center, it appears to be Top center
the other columns appear correct as middle center
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 4 von 4
als Antwort auf: kadmonkee
Thank you guys! I found the answer myself. I select the cells and then appear the adjustment panel.
Thank you!
