Alignment of Families using Planes
Message 1 of 13
Hello there can someone point me in the right direction, i have some families i have created and need to align them using strong reference planes, is this possible? or am I misunderstanding something?
Replies (12)
Message 2 of 13
Alfredo_Medina
Families will align to others by their own geometry itself. Reference planes are not necessary for alignment. The terms "weak" and "strong" are more related to how the user finds a reference plane in the project, for creating dimensions. "No reference" means the user won't see the plane in the project. "Weak" means the user will see if he/she uses the Tab key to find it. "Strong" means the user will see it just by hovering the mouse over the family.
Message 3 of 13
Thanks for this can you advise then how i would align a screw/bolt to a hole or on the centre of the rail with the hole in?
Message 4 of 13
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @Anonymous,
This all depends on how the family is built, but generally you can align center point of a circle to another part of the model. Here is some information on aligning elements.
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/RevitLT-Model/files/GUID-9C867721-1970-4ECC-90F1-3C112B9EC2E6-htm.html
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Message 5 of 13
Hi there
Please see attahed, i'm trying to locate the flange screw into a hole on the EcoAS Panel, when they are inserted into a project.
Message 6 of 13
artejon
Place a screw on a face of a panel, align it and lock.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Message 7 of 13
How would be the best way to align the screw to the hole centre though
Message 8 of 13
artejon
Ribbon> Align> hover over the hole > the axis will appear, pick it then hover over a screw untill you see an axis highlighted> pick > screw will be aligned, pick a padlock, repeat with the other axis of a hole and a screw (orthogonal to the first one).
Message 9 of 13
Hi there thanks for that I had tried hovering but no axis were appearing, and had tried tabling too, with no joy, will try again
Message 10 of 13
You align them just like you normally align other things.  I don't understand why you need a "best way" for such a simple operation.
Message 11 of 13
See above comment I was trying be.working in a 3D view
Message 12 of 13
Is there anything prohibit you from switching to a 2D view to align things then switching back to the 3D view?
If you must work in 3D views, then draw model lines to present centerlines of the holes in the host file, and draw model lines to present centerlines of the bolt in the bolt family, then use them as aligning references. Total unnecessary in my opinion.
Message 13 of 13
Thanks for your opinions, will take them on board, my user base has a vast ability range so was after the best solution to suit the ability ranges
