- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
Relative newbie to Revit here, although gaining more and more opportunities to improve. This question is for all you expert Revit users who know all the hidden tricks to make this program work best for its users.
Does setting up sheets in Revit suck as much as I think it does? Or am I just not doing the right things? Here's the situation. To me, one of the indicators of good craftsmanship is common elements showing up at the same spot on every sheet. So when you are flipping through a sheet set, the general notes, views, schedules, etc. are not jumping around. However, I am unsure of how best to achieve this result. I am aware of grid guides and have been using them but not everything on a sheet is eligible to snap in my experience (maybe I have a setting wrong?). For example, I have a legend placed on the sheet that I have to eyeball into place because it won't snap. Viewport titles same goes. You can nudge and eyeball them into place but cannot snap to a grid line. Snapping is also not an option when extending the width of a column in a table to align to a grid line. Drafting views are another issue I've run into where no snaps are available and you have to eyeball them into place.
This may be 100% user error and if so, please be kind 🙂
Thanks so much,
Liz
