Aligned Dimension Lines not marking windows
martinezgabriella
Message 1 of 9
martinezgabriella
I'm trying to set dimension lines along an entire wall that has windows. The dimension lines only mark the distance from one end of the wall to another, and does not mark the windows along that wall. I have it set to wall faces, entire walls, and openings at the center. Intersecting walls and intersecting grids are not checked. Does anyone know how to fix this, and make the window markings appear? Thanks.
Replies (8)
Message 2 of 9
Are you dimensioning a LINK wall?
Message 3 of 9
martinezgabriella
I'm not sure what that is. I have inserted a picture of the wall below though.
Message 4 of 9
You don't know whether or not it is a Link?
Post the file here.
Message 5 of 9
martinezgabriella
Just looked up what it is, and no it is not linked to any other file.
Message 6 of 9
Post the file.  The RVT. Attach it to a reply post. Know how?
Message 7 of 9
martinezgabriella
Let me know if the file works or not.
Message 8 of 9
Raise your View Range Cut Plane
...if you don't want to raise the Cut Plane, then dimension to individual references.  Or use a Plan Region. Do you know about those yet?
Message 9 of 9
martinezgabriella
I raised the cut range and it worked. Yes, I know what the individual references are, but not the plan region. I will have to look into that in the future. Right now, I am following tutorials by "CAD in black" on youtube, as his course seemed to be the best, and most comprehensive, free option. Haven't gotten to the part where he explains more complicated stuff, which is why I had no idea what to do when the dimensions didn't work. Thanks for your help!
