hide Adaptive points in family
cgambleTFFSQ
Message 1 of 26
cgambleTFFSQ
I have an adaptive point family, I have the visibility parameters set to hide them based on a yes no parameter, and in the familys 3D and plan space the adaptive points hide properly, but when its loaded into my model they still show everywhere.
Replies (25)
Message 2 of 26
Can you uncheck this box?
Message 3 of 26
cgambleTFFSQ
Thats attached to a yes no visibility parameter to have it turn off based on a different parameter.
Message 4 of 26
You can hide them by element or by category (Annotations Tab) or by filter.
I wouldn't do it through the Family. I'd handle their Visibility in Project Views.
Message 5 of 26
I don't that works with Adaptive Point.  What particular reason you want to turn them on in project?  They can still be highlighted and adjusted even they are set to Invisible in the family.
Message 6 of 26
cgambleTFFSQ
I want to see some of them, but all of them are visible. 14 is the last one that should be visible. but im seeing 15 and beyond. but in the family environment it behaves, where 15 is not visible if I set the visible points to 14.
Message 7 of 26
cgambleTFFSQ
They only hide when i turn off adaptive points in the VG and not with the family visibility parameters I have set.
Message 8 of 26
cgambleTFFSQ
I need them set in the family. long story short we use it for our egress paths.
Message 9 of 26
Preview Visibility ON is Family?
Message 10 of 26
Then select only the Points you want to show in the project and tick the Visible box in the family, leave the rest of the Points unticked.  The bottom line is the normal Visibility parameter will not work here.
Message 11 of 26
cgambleTFFSQ
Yes, and the ones i want visible are, and the ones i dont, arent.
Message 12 of 26
cgambleTFFSQ
That doesnt show as an option. and thats pretty cumbersome for every point.
Message 13 of 26
What I suggested needs to be done in the family, not project.  Do you want to select individual Adaptive Points in project and be able to turn them on or off?
If so, see the attached R22 family.
Message 14 of 26
This is about hiding a select few APs in the Project; correct?  And. what you are saying is that you can't figure out how to do that?  Should be easy enough to accomplish.  Don't know what's going on at your end.
Post your file.
Message 15 of 26
By the way, why don't you use Path of Travel tool?
Message 16 of 26
cgambleTFFSQ
I want to be able to tell the family 14, and only adaptive points 1-14 are visible, and 15 is invisible, like how it operates in the family, but when its loaded into the project environment, it shows the points beyond 14.
Message 17 of 26
cgambleTFFSQ
Because the segments cant be adjusted in the Z plane, it doesn't recognize circulatory elements.
Message 18 of 26
cgambleTFFSQ
Right, in the family environment its perfect, but in the project it changes how it displays.
Message 19 of 26
Okay, I get that. I don't get why it's such a struggle.  That's why I asked to see your file.
Message 20 of 26
cgambleTFFSQ
im not totally comfortable posting this family. my company pretty particular with the IP
