Aligned Dimension in inclined wall
I would like to know, how does make aligned dimension at inclined wall. I tried several times but I couldn't pick both end of wall. Kindly find my screen shot of said subject.
txs
RDAOU
Hi @Anonymous
  • Select the wall >> Right click the end grip control >> select Disallow Join
  • Start the Dim command >> tab the unjoined end to select first end
  • then tab the intersection Point to select second Point at the other end
  • After you place the Dimension >> go back to the first end and right click >> Allow join
  • lastly, select the Dimension extent grip and move it to the intersection (inner or outer)
I will add a screencast once it is uploaded to the server
Kindly sent me screencast if possible. Because I try but still I didn't get the steps.i reach until disallow joint after that I cannot.
Txs
RDAOU
Hi @Anonymous
Sorry for the delay ... see screencast
Edit: didn't realize @RDAOU already uploaded his screencast.
___
My dirty way of doing it.
RDAOU
@ToanDN
Even if u did  : o) where is the harm in a new trick even if it comes sometime later
___
