Align or rotate sections that are off in alignment
Marcus.Isacsson
Message 1 of 10
Marcus.Isacsson
Hi fellas!
Any workaround to align or rotate sections so that they become exactly vertical or horisontal to project north?
Our sections are about 1 degree off since the building had the wrong rotation early on.
Thanks in advance!
Replies (9)
Message 2 of 10
chrisplyler
Sure. Select one and rotate it.
Message 3 of 10
Marcus.Isacsson
But it doesn't snap to anything? How do I make sure it's 90 degrees?
Message 4 of 10
chrisplyler
Hmm....
Draw two reference planes. One perpendicular to North, and one exactly following the Section line. Put an angular dimension between them. Then rotate the Section line that amount.
PS - First set your Project Units up to display the most accurate decimal angle that you can.
Message 5 of 10
See screencast.
Message 6 of 10
loboarch
There is a little trick for this. Don't use the rotate command from the Modify tab. select the section or elevation line and use the rotate gizmo on that. This will re-initiate the "hunting" behavior of the section/elevation and it will allow you to snap to parallel again.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 7 of 10
loboarch
Edit: realized there is no rotate gizmo on a section line.
Jeff Hanson
Revit Help |
Message 8 of 10
I have just spent 5 minutes looking for the gizmo, on the section, on the ribbon, on the status bar, on my keyboard, under my mouse, in my coffee... Thought you had some superuser power haha...
Message 9 of 10
Viveka_CD
Hi @Marcus.Isacsson
It's been a while and I'm just checking back on your post to see if you were able to resolve your issue.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. This will benefit others in the community seeking similar solutions.
Thank you,
Message 10 of 10
Marcus.Isacsson
@Viveka_CD wrote:
Hi @Marcus.Isacsson
Thank you,
Yes it's solved now. Seems that I couldn't snap to the section marks if I didn't remove the middle gaps first.
