Align grid "handles" to grid lines
dlsager
Message 1 of 13
dlsager
Good day.
I would like to show that the grid "handles" are aligned to grid lines. However, I can not seem to do it. How can I make it work?
I tried the following methods:
1. Created a grid head family with the supposed "handle". It works on the top grid head only, but when it comes to bottom/left/right grid heads, it becomes like this:
2. From the family with the "handle", I tried using shared parameters with visibilities that hides these handles through a checkbox. However, it did not work.
You may see the attached file below for the grid head family.
I am not quite sure on how to call the "handle", if there should be a term for it, let me know.
Cheers.
Replies (12)
Message 2 of 13
Tom_Kunsman
Not sure this will work. The column grid ballon family is somewhat restrictive in what you can do in it. And as you saw, even if you add a generic annotation or region, it will stay in the quadrant that you placed it in.
Message 3 of 13
andr3sant0s
You could create a visibility parameter for up/down/left/right, but if you have a slanted grid line it won't be useful...
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
Message 4 of 13
handjonathan
Hi @dlsager
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Tom_Kunsman @andr3sant0s  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 5 of 13
I don't have a solution, but I am curious why you want this.  What function does it serve - assuming form follows function in this case.
Message 6 of 13
dlsager
It is a part of our company's drafting standards.
Message 7 of 13
dlsager
I did create a visibility parameter on these directions. However, it did not work. My custom-made family with these parameters is attached within the original post. Don't worry - I don't mind about the slanted grids, I just need the straight ones.
Message 8 of 13
dlsager
Hello, good day.
I am still looking for the solution - I have thought of using generic annotations for grid heads instead, however, maybe we could still find a much efficient solution.
Message 9 of 13
dlsager
Thank you very much for your insights.
Message 10 of 13
What is the "handle" for?
Message 11 of 13
dlsager
It is part of our company's drafting standards.
Message 12 of 13
SteveKStafford
Unfortunately in this case the answer is a no, Revit won't do that. It only specifies one family for both ends of a grid and it does not rotate the opposite end annotation family. They could accommodate this graphical approach if they offered a start and end grid bubble annotation and if they provided a toggle to invert the symbol at an end. Something for Revit Ideas.
Steve Stafford
Message 13 of 13
I get it is from the firm graphic standards.  But what does it do? Does it indicate some properties of a grid?
