Algorithm for constructing an ellipse embedded in a rectangle Revit Archi 2019
dedperded2025
Message 1 of 9
dedperded2025
Подскажите пошаговый алгоритм построения эллипса встроенного в прямоугольник размером 105,6см х 39,6см в Ревит с помощью стандартных линий и окружностей.
Tell me please a step-by-step algorithm for constructing an ellipse embedded in a rectangle of 105.6 cm x 39.6 cm in Revit using standard lines and circles.
Replies (8)
Message 2 of 9
bill_gilliss
This method will approximate an ellipse with arc segments, using a true arc as a guide, and is much faster than any method that requires geometric construction. The first arc segment is created using the Start-End-Radius Arc tool, and all the rest are with the Tangent End Arc tool. Easy.
64d86b08-45c9-4cbe-8eb8-18ced25d7d81,640,620
Message 3 of 9
Alfredo_Medina
Just curious, why you don't want to use the Ellipse tool to draw an ellipse?
Message 4 of 9
bill_gilliss
See if I can get the screencast to work this time:
Message 5 of 9
bill_gilliss
One more time. (It took a while for the Autodesk servers to get this ready.)
Message 6 of 9
dedperded2025
In particular, I am building an architectural wall based on an ellipse. But the drawing tools on the walls don't have it.
Message 7 of 9
Create an elliptical  mass form and generate the wall by face.
Message 8 of 9
constantin.stroescu
I'll complete that because the dimensions of the ellipse are so small you have to place Wall by Face > Finish Face Interior...
Constantin Stroescu
Message 9 of 9
bill_gilliss
I'm TRYING to get screencasts to work. Here it is as an Mp4.
